Putting true duals over the axle on my 95, exhaust shop failed
Old Oct 23, 2008 | 02:39 PM
78Z28350's Avatar
I brought my car to a well known exhaust shop who has a great reputation around here to see if he could do true duals over the axle like Gripenfelters. Before he even looked under the car, when I told him what I wanted he said "noo you can't do that the way the 4th gens are made, they can only go over one side." So I told him I've seen a car, (Gripenfelters), with true duals over the axle on both sides. He said it might have been done but "I don't recommend going through the work for that. So, should I gather pics of grips set up and head back there or other shops, or just go with single 3" Magnaflow catback with ORY no cats?
Old Oct 23, 2008 | 08:04 PM
Green96Z's Avatar
I'd say if you want true duals, don't take no for an answer. I've seen setups like what you want. They either have to notch the panhard support brace or remove it, but it has been done.
Old Oct 24, 2008 | 12:51 AM
ak95ta's Avatar
Or you could go with a 4" Mufflex single exhaust if your worried about flow. They sound badass too.
Old Oct 24, 2008 | 01:15 AM
bombebomb's Avatar
He could also dump them at the axle. It sounds like he wants them all the way back though, which is cool also.
Old Oct 24, 2008 | 10:18 AM
78Z28350's Avatar
I want dual out the back, no dumps before axle. I'm looking to spend around $1000 or lower from headers back. Do you think I should ask him to do the dual 2.5" over passenger side axle so I don't have to relocate/modify my panhard bar?
Old Oct 24, 2008 | 04:07 PM
78Z28350's Avatar
Well, went to another shop and asked about dual 2.5" over passenger side axle and they said "impossible."
After I told him I've seen numerous cars that way.
Old Oct 26, 2008 | 07:24 PM
monkey_fuerte's Avatar
dual 2.5" over the passenger side is very doable. you could even go with dual 3", but it would be a tight squeeze, and you'd have to find someone with experience doing true duals with f-bodies
Old Oct 28, 2008 | 08:44 PM
max_ta's Avatar
lokk at panhard rod relocation kit more room for over the axle and I think Texas speed has a true dual setup in stainless for the 4thgens last I heard it is 2500 bucks
http://www.bmrfabrication.com/F-bodySuspension.htm
^^^^^^^^^^^^^^^^^^^panhard rod relocator kit
Old Oct 28, 2008 | 10:10 PM
Green96Z's Avatar
That is for running true dual 3" pipes over the passenger side only, not over both axles like the OP wants.
Old Oct 29, 2008 | 09:33 AM
78Z28350's Avatar
Well, now since everyone calls down my dual over both sides I'm probably going to do dual over passenger side axle only then out the back. You're meaning to say I need a PHR relocation for that? or for over both side? I'd rather go over both sides but nobody wants to help me around here. Want to get this done before the winter comes
Old Oct 29, 2008 | 09:38 AM
mdacton's Avatar
do you know how much h.p. a 3" pipe supports?
I think your wasting your time and money
Old Oct 29, 2008 | 01:22 PM
78Z28350's Avatar
Yes dual 3" pipe supports way more horsepower than I will ever make. Thats why I'm not getting dual 3" dual 2.5" is fine for me
Old Oct 29, 2008 | 01:26 PM
78Z28350's Avatar
Orrrrr I could just say screw it all and get 3" ORY and magnaflow catback
Old Oct 29, 2008 | 02:19 PM
30AnniversaryZ28's Avatar
I've got pacesetter LTs, ORY, and a magnaflow and it sounds amazing.
Old Oct 29, 2008 | 07:51 PM
max_ta's Avatar
listen to this guy are you pushing over 600hp
look at gmmg web site, once you get 2.5 x2 over your rear end on passenger side look how gmmg runs the resonators
