Stuck Clutch Master Cyl. U Bolt....tips?
Old Oct 19, 2008 | 06:53 PM
B-Rad420's Avatar
I cant get one side of the u bolt to budge any. Both of the nuts on the u bolt and the clip that holds to "push rod" to the clutch pedal have been removed. I have tried to hit it with a hammer many times. Anyone else run into this? If so what did you do. THANKS, Brad
Old Oct 20, 2008 | 02:38 PM
TW95Z's Avatar
There is a thin metal washer on the master cylinder stud that is probably the source of your problem. It's probably used to make installation easier but it is a pain when trying to remove the stock master cylinder. Using my fingernails I was able to "unscrew" the washer from the stud.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
