Loud slam when foot is in it
Old Oct 14, 2008 | 06:38 PM
maybe2fast's Avatar
Long story!
Old lady pulled out in front of me, took it to a body shop I work next to. New Paint and car fixed, looks great.
While the front end was off I decided to fix the oil leak:
replaced the Timing cover seals and gasket
oil pan gasket, removed the pan.
Had to lift the motor (remove bolts from motor mounts) and lower K-member to get the pan out. Got everything back together and I think I tore a seal because its leaking worse...bad!
Anyways when I drive and take off from a stop or get on it around a corner in 2nd, I get this bad bang/rattle. I think its the y-pipe hitting on the drivers side right under me. I checked the bolts on both mounts and they are tight. I could see some metal shavings on the pass. mount that were magnetic like on the mount area...
If it is a bad mount why is it bad after the repair and find before the accident?
confirm my noise and diagnosis.
Old Oct 14, 2008 | 06:53 PM
Savannah Dan's Avatar
Tranny mount?
Old Oct 14, 2008 | 06:55 PM
maybe2fast's Avatar
its a energy poly mount.
Old Oct 14, 2008 | 07:18 PM
slowride94z's Avatar
how big is your foot??
I mean Iv heard of kicking the shif out of it but
Old Oct 14, 2008 | 07:20 PM
maybe2fast's Avatar
noise under car under hard/medium acceleration
Old Oct 14, 2008 | 07:32 PM
Bluovlh8er's Avatar
check the tranny mount! trust me. i broke 4 of em lol
Old Oct 14, 2008 | 07:35 PM
Is it intact? That's really what I was getting at.
Old Oct 14, 2008 | 08:30 PM
MeanGreen97Z's Avatar
That and check the torque arm.
Old Oct 15, 2008 | 06:12 AM
maybe2fast's Avatar
will check these and get back to you guys
Old Oct 15, 2008 | 07:16 AM
shock6906's Avatar
Without even looking at the mount itself, if your shifter jumps up when you get on the gas, then it's your transmission mount. My shifter would rise a good two inches when I hammered it with a broken transmission mount. I got under there, and sure enough, split in two pieces.
Old Oct 15, 2008 | 07:39 AM
maybe2fast's Avatar
thats the thing it doesn't move...
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
Latronaxe
Jul 17, 2015 11:55 AM
