Turbo 383 cam help...
Old Oct 7, 2008 | 11:13 PM
jay_rich's Avatar
Currently the car is running a 232/236 around .580ish lift(1.6RR) 111LSA.
Also if switching from this cam to the comp one will I loose alot of N/A power? I may be running the cam before the turbo goes in. Dont have the funds to do it all at once.
motor specs....411RWHP/396RWTQ thru a 12 bolt 4l60e
383 LT1(o-ringed)
forged eagle 3.75 crank
forged eagle h-beams
forged je-28cc pistons
LE2 heads
pac 1518 springs
1.6RRs
double rollar timing chain
Ported LT1 intake
58mm TB
etc
Now I was thinking of going with the Comp Cams
Comp Cams "Extreme" LT1 Camshaft, 224 / 236, .502 / .520 114 LSA, Very aggressive camshaft for street/strip blower applications. Heads, Exhaust, Stall or M6, Computer tuning required
Thanks Jay
Old Oct 26, 2008 | 08:11 AM
jay_rich's Avatar
Anyone have input on the comp cams 224/236 in my 383 front mount?
I just picked up my turbo it is a Garrett/AiResearch TH08A64 (74mm .96A/R..exh with a T6 flange)
Will this cam work good for me?
Jay
Old Oct 26, 2008 | 08:34 AM
Masnart39's Avatar
Typically, a turbo specific cam will have a couple more degrees duration on the intake than the exhaust, be smaller than you would expect @ .050", and be on a 112-115 LSA. The goal being high exhaust velosity to spin the turbo.
Very generally speaking, with 383 cid, somewhere around 218/216/114 would be a reasonable starting point. Obviously, you need to take into account your intended rpm range, cylinder heads, and a host of other variables.
Talk to a company besides Comp, where the person might actually pay attention to your needs. Cam Motion, LSM, and Bullet a a few that have produced very good results.
Old Oct 26, 2008 | 09:33 AM
jay_rich's Avatar
Thats what I thought, so this is more like a blower cam?.
I shift my auto at 6100RPM (usually goes ups to 7000rpm)
LE2 heads are on it and will be untill I have funds for some TFs.
ON a 383 wouldnt I want something a tad bigger because of it wanting air?
Also I wanted to stay around the like .580s lift on a 1.6rr so I dont need to do springs right away.
Jay
Old Oct 26, 2008 | 10:24 AM
Masnart39's Avatar
Yes
The turbo will move the air.
As I said, those specs are a very general starting point, but I would be surprised if, after talking to the mentioned companies, the specs would be much bigger. A proper turbo cam will be smaller than you think it should be.
Unless you use some very aggressive lobes, most short duration lobes will only have .530"ish lift w/ 1.6 rockers
I'd also suggest you search for info about Jim @ Speed Inc's old LT1. His combination was very successful. Although it was a 355, I believe the cam was in the 212-215 duration @ .050" range.
Old Oct 26, 2008 | 10:38 AM
jay_rich's Avatar
Engine- 359ci LT1, splayed 4bolt, eagle crank and rods, CP pistons, 8.6-1cr, AFR heads, 218/218 hyd roller.
Those are his specs....I just figured bc its a 383 I needed some more. Makes sense tho. I love his car I remember reading up on that thing.
Jay
Old Nov 1, 2008 | 06:07 PM
engineermike's Avatar
The cam you're looking at is similar to my cam, BUT...
if I'm not mistaken, you're going to use a T6 frame turbo. As long as you install a decent exhaust (3.5" at least with a straight-through muffler), your exhaust pressure should be low. If the backpressure is close to boost, then there is really no reason to go with a so-called "turbo cam". Cam it just like you would NA.
Mike
LeftoverChinese
Jan 14, 2024 03:03 PM
drptop70ss
Mar 26, 2015 01:50 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
MadMav
Feb 6, 2015 11:02 PM
