Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Need 60lb injectors WHICH ONES??!!!
Old Oct 7, 2008 | 05:28 PM
bski224's Avatar
Anyone recommend a good 60lb injectors Dont know much about them but need to get rid of my 42's and go to a 60.
Old Oct 7, 2008 | 06:24 PM
High or low impedance? Stock PCM?
Old Oct 8, 2008 | 08:44 PM
bski224's Avatar
Not sure just going by what the dyno tech told me. I thought the 42's would be good im only pushing approx 450 RWHP and he says I need 60lbs because once we go above 5,200 she goes pretty lean and he wants to add more fuel. So he was talking about the boost referance regulator and then he said I should just go with 60lb's
Old Oct 9, 2008 | 11:32 PM
If you are driving them with the stock PCM, and no external converter, you have to use a high impedance injector. That sort of limits your choices. Look at the Racetronix website.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
