LT1 Boost Budget Kit Build
Old Oct 5, 2008 | 04:15 PM
RealQuick's Avatar
Well guys, I am waiting on parts to complete the TT setup. In the mean time, I decided to build the Cast Manifold Budget Kit (complete kit with a TC 76). This is a budget kit for $5000, but you'll have to delete your A/C. Not a bad price for a kit that will support 600-650rwhp. Here are the first build pics so far:
Old Oct 6, 2008 | 08:25 PM
RealQuick's Avatar
Some more progress on 3" DP:
Old Oct 8, 2008 | 05:45 PM
IROCThisZ28ForLife's Avatar
sweeet!
Old Oct 9, 2008 | 10:28 AM
RealQuick's Avatar
Thanks Paul.
Old Oct 9, 2008 | 11:40 AM
95z28_m6's Avatar
If only it was a header kit. Still looks killer.
Old Oct 9, 2008 | 12:31 PM
RealQuick's Avatar
Thanks dude. I make header kits too... but its more pricey!
Old Oct 9, 2008 | 01:28 PM
reamo04's Avatar
too bad they dont look like they will work with the madman alternator kit
Old Oct 9, 2008 | 01:29 PM
RealQuick's Avatar
Put the alt back up top
Old Oct 9, 2008 | 05:11 PM
95z28_m6's Avatar
Yea I have been looking at them and considering a turbo setup. I could build one myself but I dont think I have enough time to piece it all together. If only that was a header kit at that price you could consider it sold.
Old Oct 9, 2008 | 09:32 PM
RealQuick's Avatar
Some final pics before paint.
Old Oct 10, 2008 | 03:48 PM
reamo04's Avatar
if i could find an alternator-only kit to put it up top, i woulda done that long ago
Maybe some day i'll stop being lazy and make one
Old Oct 13, 2008 | 05:07 PM
RealQuick's Avatar
Old Oct 13, 2008 | 05:22 PM
jsetzer's Avatar
Looking good.
How bad/hard is it to weld to the cast?
My friends won't touch it but I have wanted to try this for a budget build myself sometime.
Old Oct 13, 2008 | 06:02 PM
RealQuick's Avatar
Originally Posted by jsetzer
Looking good.
Its not bad. You should use a hand held heat source (propane torch) to heat before and after you lay the welds. Also, you need the welder turned way up, so you can see the weld melting into the cast iron. if the weld bubbles up ont he surface of the weld, then you arent penetrating enough. Grind it flat and do it again.
Old Oct 14, 2008 | 07:59 AM
jsetzer's Avatar
Thanks, I'll give it a try sometime.
