Running very bad !
Old Sep 27, 2008 | 12:10 AM
KUGSS's Avatar
Running very bad !
After four years of my car sitting in my drive way i thought it was time to get it back on the road. I stopped driving it because it stopped running right, it dumps so much fuel it looks like a big rig. I have replace o2 sensors and tried different MAF sensor but no change. I noticed that theres no vacuum at an idle so started to look for an leak even pulled the intake off to check the gaskets but all looks good. Did a compression check on the left bank all around 150psi will check the other side on saturday. The car wont idle unless your foots on the throttle a little bit but will soon flood its self out. Before i parked it i replace the opti it has like 3 miles on it but no change. My car has a355 with 9.1 comp p600b with 12lbs pully #42 svo injectors lt4 intake crane cam auto msd 6a with coil hooker sumper comp headers no mufflers just an x pipe with side outlets 255LPH intank pump with a inline booster pump ngk tr6 plugs and taylor wires no tunning done yet but drove the car for 7 mounths with no tunning. Any opinon would be great. im getting ready to shoot this thing
Old Sep 27, 2008 | 11:58 AM
WS6T3RROR's Avatar
One or more stuck injectors, or a ruputred fuel pressure regulator. Spark plugs will likely tell you the story on that. I wouldnt even attempt to fire it until i was sure i had a handle on the problem, it doesnt take alot of fuel to fubar the ring seal good.
Old Sep 27, 2008 | 10:07 PM
KUGSS's Avatar
Thanks for the info but i replace the intake gasket and it runs good now
Old Sep 28, 2008 | 01:01 AM
2xLS1's Avatar
I'm sure it runs real good with those 42# injectors and no tuning.
grabbem88
Feb 13, 2015 03:09 PM
Amshnock
14
Jan 18, 2015 11:47 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Z284ever
43
Jun 27, 2002 10:36 AM
