Finally found out 99 ls1 injectors will work on 3.8 need help on fuel pressure
Old Dec 31, 2002 | 09:58 AM
bluecmaro96's Avatar
I recently received a picture of a 26lb 99 ls1 injectors and it looks the same where the connector is so im pretty sure it will work, im just confused because the ls1 sprays 60 psi fuel pressure and my v6 is only 50 psi, how would i compensate for this so i could properly run the ls1 injector? I will be getting my pcm programmed and using a walbro in tanks pump but how wil i get it to spray at the right fuel pressure on my 96 3.8 thanks for any help
Old Dec 31, 2002 | 10:39 AM
PhantomTA's Avatar
Moderator
At the v6 pressure those injectors are not 26lbs..
Put it this way, a 30lbs injector in a ls1 is something like 36lbs
Old Dec 31, 2002 | 02:31 PM
that almost makes sense please someone else let me know
LT14LIFE
Feb 9, 2015 09:35 PM
Gtpguy
Jan 26, 2015 04:50 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
Burn_Out
Aug 18, 2002 08:49 AM
