White sludge in valve cover air breather.
Old Dec 30, 2002 | 09:55 PM
pacesetter's Avatar
Well I took the air breather off to clean it and polish up the valve covers. On the right side ( drivers side ) valve cover air breather there is this white sludge inside of it, what the hell is it? The other side doesnt have it. Im not sure if its do to age of these valve covers or what.
Old Dec 31, 2002 | 05:17 AM
Guido67SS's Avatar
I don't know but if its white and sludge you better get to the doctor really quick....
Its water. When moisture mixes with the oil, it will turn it white. It is not unusual to get a small amount of this under certain conditions, especailly with aluminum valve covers, but it could be an indication of a problem. Does it go away when the car is run at operating temp? It should burn off after the motor gets hot. If not you may have a coolant leak.
Good Luck
Guido
Old Dec 31, 2002 | 11:57 AM
1981zzz's Avatar
It sounds to me that u might have a crack in the head or a blown head gasket check your rad see if there is white sluge on the rad cap or in the rad thn check your oil for the same if not then do a compresion test that will tell u if you have any blowby the vlves or rings good luck hope its nothing to bad
Old Dec 31, 2002 | 12:30 PM
pacesetter's Avatar
Well there isnt alot of it, its just inside the one air breather not actually on the valve cover....... there isnt alot of it either I just havnt seen it before. Now keep in mind these valve covers sat on this engine for 7 years b4 I started her up for the first time in awhile and Im still using them But I just gave it an oil change and checked the rad .... no white stuff
Old Dec 31, 2002 | 01:16 PM
pink68's Avatar
I would imagine its condensation from shutting a hot motor down and letting it cool off.
jim
Old Jan 1, 2003 | 07:17 PM
1981zzz's Avatar
glad its not a crack or head gasket it probably was just a bit of dampness in the cover wat a relief A
Old Jan 1, 2003 | 10:20 PM
97z28/m6's Avatar
lern hoe to spel wil you.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
