Rear Clunk
Old Dec 30, 2002 | 05:58 PM
webdoc's Avatar
Rear Clunk
My 98 Z-28 T-6 has has a clunk coming from the rear for sometime when I take a right turn. It bangs going around the turn and again when the body levels out. No noise on left turns. This is loud. At Pocono Raceway, a corner worker told me they heard it when I came around the right hand hairpin curve.
I don't know when it started. I lubed the lower spring pads, new shocks, new poly bushings all around and new LCAs. I have torqued all of the bolts and have looked around for signs on contact with no clue. Could it be the differential? I have 45k miles. I do have a new Torsen T2r to install this winter.
Any ideas?
Old Dec 30, 2002 | 11:50 PM
danno02SS's Avatar
It is the differential. Both Auburn and Torsens seem to have it. It's a clunking sound during tight low speed turns. I usually get it on left turns. I had the differential serviced a while back and it helped out alot ( the noise went away for about 1.5k; I now get it occasionally). You might wnat to try that.
Old Dec 31, 2002 | 01:58 PM
GoFast908Z's Avatar
Member
I had a very similar sound in mine too. It turned out to be a broken transmission mount. Check that out too. I got mine replace and have not heard it since.
Old Dec 31, 2002 | 04:24 PM
My ambitionz's Avatar
i got the same problem but mines is more of a groaning noise if i cut left or right or if i pull out in reverse and make a turn then i really hear it, my car is also a 98 m6 with 29k miles, but my rear control arms are squeeky,gonna do a rear suspension overhaul. i know when i first got the car and i would shift into gears it would clunck i blamed u joints so when i went to put my gears in i just replaced all u joints and the tranny mount. i know when i loosened the yoke nut it wuz not tight at all, it came off real easy with no hard struggle, i men they arn't suppsed to be tightened all the way but this was really loose the crush shim wasen't even compressed.
I tightend/torqued it to specs ad no more cluncks or rough shifts.
Old Jan 2, 2003 | 11:03 AM
rncotton's Avatar
This sounds like something more than the standard Torsen float noise. You shouldn't be able to hear that outside the car.
My '01 Z28 had a nasty clunk for a while. It turns out the the boot where the rear suspension mounts up wasn't seater properly.
Old Jan 2, 2003 | 10:35 PM
4.10Formula's Avatar
I agree with GoFast908Z. Check the transmission mount. My car had a bad clunk also and thats what it turned out to be.
HarleyZ28
Oct 5, 2015 06:23 AM
warmeck
Mar 22, 2015 06:43 PM
Fatdog2
Feb 12, 2015 12:24 PM
ModdedNerd
Dec 18, 2014 10:52 PM
