SLP takeoff Z28 shocks.
Old Dec 30, 2002 | 01:00 AM
Team Untouchable's Avatar
Has anyone done this. I need new shocks and was wondering the ride. I know they are Z28 shocks which I believe are stiffer than our v6's.
Old Dec 30, 2002 | 11:06 AM
All_InTheRED's Avatar
I have them on mine.
The ride is fine....just a bit better than stock.
But I also have a '99 takeoff springs, with 1LE sway-bars.
Old Dec 30, 2002 | 11:35 AM
SixVi6-Camaro's Avatar
they are very close to the same as on teh v6's. I'd only put those take off shocks on if you wanted to freshen up your stock suspension. I'd bet most of the improved feel is more from putting fresh shocks on then them being more stifly valved.
Old Dec 30, 2002 | 11:56 AM
CODY BEHNKE's Avatar
Most V-6 had way softer springs and shocks, the Z28/Formula/Trans AM shocks are a bit harder than stock V-6 ones unless it has Y87
Old Dec 30, 2002 | 01:16 PM
blue95's Avatar
agreed for the most part...they are a small upgrade....but for $50 a set you can't beat them!
Old Dec 31, 2002 | 12:04 AM
You are right Blue 95. For $50 a set and $25 for shipping you really cant beat them. I dont really care about the "performance" aspect of the stock shock, I just dont want to feel every little bump and dip in the freeway like I can now.
Would the takeoffs be OK with my Eibachs?
Old Dec 31, 2002 | 01:42 AM
99blackSS's Avatar
If your going to put new shocks on might as well get really stiff ones that way you can go through turns fast, this way your not limited to driving fast only on straight aways, good times.
Old Dec 31, 2002 | 11:23 AM
blue95's Avatar
[i]
Would the takeoffs be OK with my Eibachs? [/B]
what eibachs do you have now?
Old Dec 31, 2002 | 11:35 AM
ImportKILLER's Avatar
Eibachs will eat the take-offs...I wouldn't use them together.
Old Dec 31, 2002 | 11:44 AM
scamaro's Avatar
i have take offs with my eibach pros and the ride is not all that bad, highly recommend subframe connectors if your car is lowered.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Richardan15
May 30, 2015 08:36 AM
Kyle@SLP
Jan 7, 2015 02:09 PM
