t56 noise or rear end
Old Aug 22, 2008 | 03:48 PM
onetransam4u2nv's Avatar
I have a 95 formula with t56 and 4 10 motives recently i have had some clickin thats almost a thumpin lol that seems to go away when im on the gas but when i let of is click click click jacked up to se where it was coming from seemed like it was comin down the drivetrain the tranny shifts fine thru all gears it has a spec stage 3 clutch i just have no idea what it can be any help would be great thanks jack
Old Aug 27, 2008 | 05:05 PM
found it
well i pulled cover off the rear end and had 3 teeth broke off ring gear anyone else had this happen? and reason why it happened i know the rear ends are weak but are the ring gears the weak point or did the woodchuck that put the gears in mess them up? opinions please
Old Aug 27, 2008 | 05:33 PM
Prorac1's Avatar
I have yet to pull the rearend cover, but im sure this is my problem as well. I dont know about you, but my problem came in the way of et streets, a sticky drag strip, and a centerforce clutch launching a 4000 rpm......................instant bering noise and clicking. Probably just abuse of a weak rearend. Hope this helps, Eric L
Old Aug 27, 2008 | 06:56 PM
nope
i might lite them up once in a while but never had any drag radials never been to the strip. who knows it just sucks
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
