Bell Housing removal
Old Aug 19, 2008 | 12:51 PM
Super8Motel's Avatar
I recently removed the 6 speed transmission from my '95 Z28 and do not have enough clearance to remove the top 14mm bolt of the bell housing on the driver's side. Any suggestion other than pulling the engine? Thanks.
Old Aug 19, 2008 | 07:38 PM
Green96Z's Avatar
Loosen the motor mount bolts and jack the front of the engine up. I know that bolt, it is a PITA.
Old Aug 19, 2008 | 07:50 PM
mdacton's Avatar
that bolt is a real bitch.....
You have a swivel? I think its a 9/16" also not a 14mm, the 14 will be a little tight on it. So see if you can get a swivel or a stubby or flex head gear wrench
NewsBot
May 18, 2015 03:40 PM
BigWil
Mar 29, 2015 12:24 PM
4586
Jan 3, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
