o2 sensor help
Old Jul 28, 2008 | 09:57 PM
paul12001's Avatar
o2 sensor help
whats up guys i have a 96 z with hooker long tube headers and my o2 sensors are bad. i need O2 sensors and extensions. I went to order sum and there are like 3 or more different sensors with diff conections. Can sumone help me out and point me in the direction i need to go and also a good place to get both. thanks!
Old Jul 29, 2008 | 05:29 AM
The two pre-cat (front) sensors use a flat 4-pin connector. The two after-cat (rear) sensors use a square 4-pin connector. Shoebox has a website with part #'s for many LT1 parts, and a recommended source for discount prices.
Home:
http://shbox.com/1/4th_gen_tech1.html
Parts list:
http://shbox.com/1/Parts.htm
1996-1997 front heated oxygen sensor
AC-Delco # AFS75 19178930
(old 25312184)
1996-1997 rear heated oxygen sensor
AC-Delco # AFS97 25312196
Parts source:
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Generally recommended that you use only the AC/Delco (or now Delphi) OEM sensors.
For harness extensions, look at the list of Supporting Vendors linked at the top of each page. Start with Thunder Racing.
Old Jul 29, 2008 | 09:53 AM
paul12001's Avatar
O2
I have longtube headers and No cats. Does that mean I only have 2 front O2 sensors or is there still 2 sensors in the rear?
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
