transmission wont shift right
Old Jul 15, 2008 | 08:46 AM
rocketz28racing's Avatar
I have a 95 camaro z28 and the transmission doesnt want to shift into 2nd gear anymore. The transmission is a built 4l60e with a transgo shift kit and 2500 stall. What happens is when its about to shift the rpms jump to 4000 and it wont shift unless you let off the gas a little and then at like 60 its running almost 3000 rpms and sounds like im driving a pro street car now. Does anyone know what could cause this and how I can fix it?
Old Jul 15, 2008 | 03:07 PM
Performabuilt's Avatar
Supporting Vendor
I would bet you are actually shifting 1st to 3rd and skipping 2nd and have no 4th. Its likely the band lug pin area its broken through. Its a common failure with a stock band and a aggressive shift kit
Old Jul 16, 2008 | 03:30 PM
If it is that can it be fixed without taking the transmission out?
Old Jul 16, 2008 | 04:01 PM
JakeRobb's Avatar
Super Moderator
I'm no 4L60 expert, but I highly doubt that.
Old Jul 16, 2008 | 09:18 PM
Supporting Vendor
No it cannot it will require removal of the trans and disassembly
Old Jul 29, 2008 | 10:06 AM
rallysport92's Avatar
My trans is doing almost the same thing. I have a 92 RS 3.1 stock and when I take off easy it rolls up to about 4500 before it starts to shift then it shifts fine. Then when I get at highway speeds, it cruises at around 2700-3000 but jumps back and forth to around 1500.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Apr 16, 2015 09:57 AM
jackpawt883
Feb 26, 2015 09:04 PM
