shift softening procedure ?
Old Dec 25, 2002 | 10:11 PM
LWM's Avatar
LWM
As above, just how exactly does one go about the process of softening up the shifts?
Low speed and part throttle ...
thx for any input
LWM
Old Dec 28, 2002 | 12:23 PM
oemfisystems's Avatar
It depends on what you have done for shift kit, and any PCM programming that has been done. Sift firmness is based on TPS% versus vehicle speed, and if you have any numbers in the low % areas that you can subtract from, then that would work, but however, if the shift kit is too hard, and you have no positive numbers to subtract from, then you have to mechanically lower the line pressure, which brings us back to the question of what shift kit do you have, if any, and what method did they use to raise line pressure? Many tunr in the PCS solenoid screw to raise the bias pressure, but it never really work well to try and turn the crew back out, in which case, if turning in the screw was done, replacement of the PCS solenoid would be needed. Hope this helps!
jim
Old Dec 28, 2002 | 01:15 PM
OneFlyn95z28's Avatar
I found the best way is to do it in the Shift offset area
Old Dec 28, 2002 | 02:57 PM
LWM's Avatar
LWM
So to make a shift softer, would I be reducing the given value or values in the offset table? ie going from a value of -6 at 18% tps to something like -9?? Will that small change make a noticeable difference?
Or, do you go the other way and increase the size of the value in the table?
The shift kit in it is a mild SK shift kit. Makes the car feel about like it was with the HPP+ shift firmness option checked.
thx for the help
LWM
Old Dec 28, 2002 | 03:29 PM
Fom -6 to -9, yes, start there. remember to smooth and transition the area where you make your changes.
jim
Old Dec 28, 2002 | 10:48 PM
LWM's Avatar
LWM
jim
Thx for the help, I was leary of making any changes in that table without some guidance ...
Gives me a good starting point ...
LWM
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
