96 4l60e into a 95?
Old Jul 13, 2008 | 09:05 PM
brahm's Avatar
96 4l60e into a 95?
I have a 69 camaro with a 95 lt1 setup in it, harness ect. Will a 4l60e out of a 96LT1 work with the 95 Harness, or do I need to change anything? Also will I still be able to use a 700r4 Converter?
Old Jul 14, 2008 | 11:33 AM
Performabuilt's Avatar
Supporting Vendor
You can do this, You will need to install the 95 internal trans harness and the additional PWM solenoid to fool the PCM and the 3-2 solenoid but it should be fine after that
Old Jul 14, 2008 | 12:20 PM
brahm's Avatar
Got any links of how to do that? hmm
Old Jul 14, 2008 | 03:14 PM
brahm's Avatar
hmm i talked to these guys. http://www.transmissionpartsusa.com/...-00k77929u.htm
they told me to get the 95 harness to work in a 96 you have to change the valve body as well..
Old Jul 14, 2008 | 05:23 PM
Supporting Vendor
Well I am blind apparently I saw 94 in a 95 now a 96 in a 95 can be done as well , You would need to swap the harness and the two round solenoids at the front from the 95 to the 96. Now heres the deal there is a slight different in the 3-2 strategy on the 96 verses the 95 some people have issues with odd or clunky 3-2 down shift when the valve body if not swapped. Personally having done it on my own car i did not see it as a big issue and drove it two years like that with no problems.
Once you open pan changing the wiring harness and the two solenoids is self explanatory.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
