Ignition switch bolt size
Old Jul 6, 2008 | 09:58 PM
tom3's Avatar
what's the size of the bolt holding the ignition switch on a '95?
This is the 4th time I've to replace that POS, it gets burnt every time. Now I've very few tools with me and I can't fit a socket, so I can't find the size of the wrench I need to get
Old Jul 6, 2008 | 10:07 PM
Listed in my replacement guide, the head on the bolt/screws are 8mm.
Old Jul 6, 2008 | 11:16 PM
tom3's Avatar
cool! thanks!
I don't get it: the switch always gets burnt, but not the wires; it always burns inside, so the contact is not the problem...
maybe there's too much load (starter getting bad )
Old Jul 7, 2008 | 07:36 AM
Maybe. Got any aftermarket stuff that requires lots of power?
Old Jul 7, 2008 | 01:20 PM
tom3's Avatar
it's always the cranking contacts that get burnt, not the rest. so the only thing I could think of is that either the motor's hard to turn (and there would be other more noticeable problems ) or the starter's going bad (it was rebuilt once).
Now, as a side note: I've tried to jump start the car a few time with other cars and it just doesn't work with most; I mean the engine barely turns a bit and it stops but when trying with SUVs, etc. Maybe this made the contacts overheat...
I'm really tempted to put an on/off switch and a crank push button. the alarm I have disables the car when it is on, so it could work.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Jan 11, 2015 03:47 PM
Jul 4, 2005 05:00 PM
