Smoke T/A, AHARTZ28, Nighttrain66...
Old Dec 24, 2002 | 12:04 PM
Trans AM 22502's Avatar
Whoever, doesn't matter who it is: I need $400 of port work done. Don't need oversized valves, was told to avoid 3 angle valve job if not rebuilding, so don't need that.
I'm doing heads and cam and I need any of the above 3 to replace my springs and valves, and port and polish the heads.
Old Dec 24, 2002 | 08:49 PM
Smoke T/A's Avatar
I could do them for you. Email me and give me the lo down on them.
Old Dec 25, 2002 | 11:49 AM
Smoke T/A's Avatar
Lloyd or Ryan I think they are a little closer to you. I've never seen Ryans work but I heard its top notch from the people he has worked on their cars. Lloyd is a excellent porter but not sure what his schedule is like. I could do them for you in about 2 weeks from now. LMK either way who you are going with.
Joe
Old Dec 26, 2002 | 08:29 AM
If you feel comfortable discussing it here its fine by me. I realize that flow numbers aren't the end-all-be-all head characteristic so I just need $400 or port work done.
To be quite honest, I'll probably go ahead and have Lloyd do them but I want to accomplish 2 things throughout this whole ordeal:
1) Find the best deal available to myself
2) Give each of you the opportunity to tell me your process and what you personally feel you're capable of consistently.
Old Dec 26, 2002 | 09:55 AM
NightTrain66's Avatar
check yer PM's
Old Dec 26, 2002 | 10:35 AM
I read it. I posted in the LT1 Tech forum about my budget issues.
I have received 2 replies, both very helpful right now.
One is saying wait until I have enough to do everything I want to do. The other is saying do some modding, which is half of what I was going to spend anyway.
Based on the responses, I'll decide what I should do. I couldn't keep shortchanging my budget, most of the stuff I needed I cut and still looks grim.
Right now, I'm thinking of just running some shorties, replacing my starter (broke) and intake elbow (ripped), and doing a Tune-Up. That alone runs me about $625. Then, with $400 port work, $80 for valves, $75 for valve springs, I'm fastly approaching my budget limit. I'll let ya know either way.
Old Dec 26, 2002 | 11:35 AM
bad95z28's Avatar
Don't forget gaskets and valve stem seals and all of the other little things that go along with it. Good luck. I've seen work from Lloyd and Smoke t/a. I've ridden in Joe's car and I know what kind of cars Ryan builds so you really can't go wrong with any of the above choices. I would consider at least getting bigger valves if you can budget it. That's one thing I didn't do and I wish I would have. You won't be dissapointed.
Mike
Old Dec 26, 2002 | 06:45 PM
Smoke T/A's Avatar
If it were me i would wait till you have money to pay for every thing you want. Don't skimp on the little stuff cause you will aways regret it later. I know form exerience! But out of all 3 of up i would have to say lloyd is the most expreienced and qualified one to do the porting job. I can hold my on though. I think fixing all your current problem areas would be a good idea before you start tearing in to the motor. Just my .02$
Joe
Old Dec 26, 2002 | 07:59 PM
AHARTZ28's Avatar
I would fix the little problemas as well..as for the 3 angle vlave job you will need to get some sorta valve job if porting is done wether its a 3-5or 7 angle ..
i can do the port work for you as well if you like i have a set of nice heads that will be for sale soon with 2.00 and 1.56 v alves and will flow 26x-27xi and 20xe
Old Dec 27, 2002 | 08:20 AM
Well Ryan, what I need from you is to "put everything back on".
I took all of those sensors and crap aloose such a long time ago that I don't remember where all of them go.
Let me know when you're available to do that. I've decided to just replace the stock exhaust manifolds for now, the manifolds were a pain to get off, super restrictive, so I'm just gonna pick up some headers.
Do you charge extra to put the "other stuff" back on? Like the water pump, fans, that type of stuff. I'll do it, just need your help as far as the lines and hoses. Wouldn't want my heater core hose going into the TB.
You can give me a call at work today from 7:30AM until 4:30PM and we can discuss it. My work number is 828-1155.
In regards to the heads, I just shelled out $400 to get my heads resurfaced, pressure tested, and cleaned, so I have invested alot of money in these heads. They are 93 heads with 68,000 miles on them. I'd consider buying the others but It'd have to be a reasonable deal seeing as how I just spent $400 on the pair I have now.
Still battling rust with regards to the engine. Any tips on how to get that under control? I turned the engine by hand 2 days ago and its not seized. I DON'T think I wore any rings, but I still need to buy a compression tester and do a test. I coated the cylinders with oil to cut down on the rust, but the other holes and the mating surface of the block is still getting SURFACE rust on it.
I want to try and get this done by next weekend at the latest. In the meantime, I'll try and clean the block and intake up a little more and do a last minute double check on everything I need to get it running.
Edit: If/when you call me at work, ask for Aaron.
Also, can you reuse a head gasket IF the engine was never turned over? I started putting everything back on, but was advised to take it BACK OFF to avoid having the rust in the cylinders wear down the piston rings. I took the heads BACK OFF, and placed the gakets back in the box. They were "moist" some how, don't know if the rain soaked the blanket I had over the block and seeped in past the heads on to the gasket or what, but I want to do everything right this time around seeing as how the guy who sold me the car screwed me.
After I tore the top end off, I noticed that something had already been done to the engine. The timing cover has some red RTV on it, shoddy job at that, the bolts on the back of the head were stripped, and the gasket was already blown, he just changed the oil right before he sold it to me. The temperature didn't surge when I test drove it for 15 minutes, but anyways, I'd like to start over with a stock quality block.
Bxlt1
Sep 29, 2015 03:18 PM
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
