Exhaust rattle
Old Jun 22, 2008 | 01:54 PM
H2O's Avatar
H2O
Exhaust rattle
I have a Magnaflow catback that has been on the car for about 2 months. When it gets hot, it seems to cause a rattle. Anyone with fitment tricks? My guess is that it is hitting the driveshaft. i have tried to adjust it, but no matter what I do, I cannot get it to clear enough.
Old Jun 22, 2008 | 01:58 PM
Have you checked to see if its hitting the sheetmetal "g-load" brace that connects the right and left floorpans, right under the intermediate pipe? That's a common place for exhaust sytem interference.
Old Jun 22, 2008 | 02:02 PM
H2O's Avatar
H2O
It does hit there if I rotate it off the driveshaft. It only appears to be hitting the lower half of it. Can I cut it down here, or is important for structure / strength?
Old Jun 22, 2008 | 04:21 PM
H2O's Avatar
H2O
What can "safely" be used to wedge into this area? I am pretty sure its the over the axle portion of the I pipe thats hitting. I read tons of posts. Some have used radiator hose, muffler tape rolled up....What would work best?
Old Jun 22, 2008 | 05:16 PM
If its hitting the sheet metal g-load brace, simply space the brace lower with some washers between the brace and the floorpan brackets.
Old Jun 23, 2008 | 07:50 PM
H2O's Avatar
H2O
I got if off there, but now its hitting the body over the axle. This is where I was asking about cutting, not the floorpan brace.
Old Jun 23, 2008 | 08:55 PM
Camaroldy's Avatar
Smile
I had a similar problem with my Magnaflow on my 01 vert. Solved it by loosening all of the U-bolts and jamming rubber shims into the hanger after the axle. I usually have to re-tighten the hanger once a year.
Old Jun 24, 2008 | 03:59 PM
H2O's Avatar
H2O
Sounds like a potential fix
Old Jul 2, 2008 | 02:56 PM
H2O's Avatar
H2O
Update:
I installed three washers on each side of the brace in the center of the car. No more rubbing, and the car is a lot smoother now. I did not realize how much vibration I was picking up from this. I assumed it was the driveshaft, but not any more!
thanks for the help all
jim
Old Jul 2, 2008 | 05:56 PM
Update:
jim
Just curious why you didn't believe me? Serious question.
Old Jul 2, 2008 | 08:58 PM
H2O's Avatar
H2O
It was your suggestion I took. I also had a rub over the axle. Thats the part that concerned me the most. As always your suggestions are correct. Thanks Injuneer
kxrawx
May 25, 2015 08:29 PM
May 15, 2015 10:43 AM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
Klypto
Jul 19, 2002 07:25 AM
