code p0358
Old Jun 13, 2008 | 11:31 PM
Garcia95's Avatar
code p0358
ignition coil H Primary/Secondary Circuit Malfunction
can someone help me out thanks
i got this code on a 99 Mercury Marquis
Old Jun 14, 2008 | 05:27 AM
95camaroinok's Avatar
Either a wiring problem or computer problem. Find a wiring diagram for the car and figure out which pins those wires go to on the plug for the computer, Check for continuity. If the wires read ok then it may be a computer problem. Its also possible for a cam sensor or even a crank position sensor to cause the computer to throw a code like this. Start checkin wires. Try searching some ford forums to see if its a common problem with those cars, maybe someone has a simple fix already. Should also be able to find how to test those sensors.
Old Jun 14, 2008 | 11:56 PM
Garcia95's Avatar
thanks man
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
