A little walk through of our stage 2 LS6 heads :)
Old May 31, 2008 | 05:50 PM
PortMasters's Avatar
Well,
We just did a set for a customer and took some pic's as we where going through the process. Hope you guys enjoy
Carter, deep in his grinding mode.
After hours and hours of grinding..the final shape takes place!
The chambers on these, where not touched due to the GIANT cam the customer is using..we didn't want to loose any compression and can't mill.
Ahh finished with the crude grinding.
All done!
On the bench for the last time
Mmmmmm new parts!
Ready for assembly
Carter checks the valve clearance, for the final time.
Old May 31, 2008 | 05:51 PM
Measuring the final installed height..no shims needed here!
All ready for their new home (99' C5)
Shrink wrapped and ready for shipment
Old Jun 2, 2008 | 09:44 AM
ZIM's Avatar
ZIM
looking forward to getting them on the car!
Old Jun 3, 2008 | 07:52 AM
teke184's Avatar
so what did they flow? and what did they cost?
curious....you mention a guy named carter....any chance its carter edwards??
Old Jun 3, 2008 | 03:08 PM
These where $1,800.00 and included a brand new set of GM 243 Castings. We generally see more CFM than these..but with the inability to un shroud the valves and rework the chamber..they are about 10cfm low at peak. (generally we will see around 320-325 @.650)
Yes that is Carter Edwards doing the port work on these heads. He is amazing with a grinder!
Old Jun 3, 2008 | 04:09 PM
ZIM's Avatar
ZIM
heads are here. they should be on the car in the next couple of days.
Old Jun 3, 2008 | 06:30 PM
Very cool,
When are you going to meet up with jeremy?
Old Jun 3, 2008 | 08:27 PM
ZIM's Avatar
ZIM
im not sure. i will call him when its all back together. ill make sure you get the dyno numbers.
Old Jun 4, 2008 | 08:06 AM
teke184's Avatar
ha...carter did my cam install 3 yrs ago.
i'm sure he'd remember too....i'm the one that had a hose clamp in the combustion chamber.
Old Jun 4, 2008 | 10:18 AM
Jeff!
Haha, David just told me about this post. That was the coolest thing I have ever seen taking off a cylinder head lol. How is the car coming along?
Carter
Old Jun 4, 2008 | 02:14 PM
teke184's Avatar
not much has changed. things got very expensive around my town after the 2 hurricane years. rent went up $400 a month.
not to mention there were some other issues to work out.
swapped in a good clutch...then pulled it all out again a year later for a busted slave (which was new with the clutch).
bought some used ZR1s...315s out back to hook the beast up.
rear end girdle to keep the 10bolt together for a while
biggest power change has been the 3" true duals that i fabricated in my driveway.
saving up for the next line of mods. thinking of going with a ported FAST 92/92 for the time being. even though i KNOW i need heads. the intake i can do on my own in my apartment parking lot.
heads are not only $$$...but so are the small things that go with them...gaskets, bolts, injectors, possibly new pushrods etc....on top of the fact that it would not be an easy thing to do in the driveway.
might look into you guys when i decide to get heads.
what do you charge for mild port work and milling? i have a good set of BARE 241 heads sitting here. mild port/polish, mill for 11:1 compression, new valves and hardware?
any quotes?
Old Jun 4, 2008 | 04:43 PM
ZIM's Avatar
ZIM
not true. i had the heads off the car in 1 hour and 59 minutes. its my first time working on an lsx engine and there was at least 20 minutes of phone interuption.
Old Jun 5, 2008 | 09:49 PM
ZIM's Avatar
ZIM
car is back together and running. tuning will be done in the next few days.
Old Jun 6, 2008 | 11:55 AM
Damn Scott,
You work fast!
Old Jun 6, 2008 | 03:52 PM
ZIM's Avatar
ZIM
tuning tomorrow after lunch.
just have to swap the bigger injectors in and get her dialed in.
thanks for getting the heads to me in a timely fasion! you sent them out monday and they were in my house when i walked in from the gym at 10 am tuesday. i would have had them on sooner but i had to wait for the new lifters.
