Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Cleaning fuel injectors idea
Old May 31, 2008 | 10:37 AM
kgkern01's Avatar
First off, I know this is not a substitute for a professional clean/test, but I think that it would still give an improvement vs in-tank or on car cleaning. Please correct me if wrong.
I was thinking of gravity or probably pressure feeding a cleaner or solvent such as de-natured alcohol (brake cleaner), Techron, SeaFoam, Xylene, etc. through the injector while connected to either a 9V battery or 9V+2AA batteries for 12V to keep injector open. Would this help to clean out the injectors without causing any damage to them?
Again, I know this is no substitute for a professional cleaning, I just want to know if this would be more effective than an in-tank or on-car cleaning, while still being safe for the inectors?
Old Jun 3, 2008 | 05:36 PM
Kevin Blown 95 TA's Avatar
I wouldnt do that - I would find a way to pulse them on and off while squirting the cleaner through them. If you leave them on you might overheat the coils - although I am not sure what happens to the coils at low voltage. If I was going to set up a rig at home to clean the injectors I might just use a fuel rail and manifold setup and pump and switch the injectors with some kind of inexpensive PLC. You would have to do a buch of cleanings to pay for it unless you got one for free somewhere.
AdsoYo
May 2, 2018 03:21 AM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
