Will a '96 radio work in a '94? Pontiac question
Old May 24, 2008 | 12:48 PM
ElevensOrBust's Avatar
Can the AC Delco units be switched easily between years? Thanks.
Old May 27, 2008 | 08:33 AM
PentaVolvo's Avatar
depends on bose/non bose
Old May 29, 2008 | 11:33 PM
Green96Z's Avatar
Not really. The difference is in the harness. The Bose one has an extra wire for the amp on/off signal. The radio should work fine.
Old May 30, 2008 | 06:27 AM
Yes, the radio seems to have an extra connection on the passengers side that my harness doesn't have. I'm still in the process of getting a wiring schema to see if there's an issue.
Old Jun 1, 2008 | 05:02 PM
neil350's Avatar
I have used an 01 Monsoon in my 93 T/A, had a friend use my stock 93 radio in his 94. So far as F-car radios from the birds, they are interchangeable. Even had a CD player from a Malibu in my TA at one point
Old Jun 2, 2008 | 08:12 AM
PentaVolvo's Avatar
The issue comes into play that 93-96 bose cars used a low level output to power the amp where as all 97+cars used a highlevel output regardless of if it was monsoon or not
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
Jul 4, 2005 05:00 PM
