I need help
Old May 24, 2008 | 10:29 AM
daxman's Avatar
I need help
I have a 01 SS and the service vehicle light stays on. This is not the service engine soon light and I have been told it will take a combination of pumping the brake, gas pedles and turning the car on and off to turn the light off. All the dealerships services are closed for the weekend out here so they are no help. Does anyone know what needs to be done to turn this light off? Please help if you can. Thanks.
Old May 24, 2008 | 11:13 AM
Do you mean the "change oil" light?
From the 2001 Owner's Manual:
How to Reset the Oil Change Light
After changing the engine oil, the system must be reset.
1. Turn the ignition key to RUN with the engine
turned off.
2. Push the TRIP/OIL RESET button located on the
instrument panel for 12 seconds.The OIL CHANGE
light will start to flash to confirm that the system is
reset. The reset is complete when the OIL CHANGE
light goes out.
Old May 24, 2008 | 11:39 AM
twozs's Avatar
the svs light means that one of your daytime running lights are out
Old May 24, 2008 | 08:25 PM
daxman's Avatar
Help
The light is out. Thanks for the help.
