Cable failure..
Old May 7, 2008 | 04:10 PM
flyinZ's Avatar
Cable failure..
Im trying to figure out whether my cable is junk, or I dont have it hooked up in the port correctly, or my comp. port isn't setup correctly...Anybody have any tips? Im just trying to read the car, then upload a file...hopefully to datalog after that..Car is in sig.
Using an USB port cable, OBD1.
Old May 7, 2008 | 06:01 PM
dookie454's Avatar
Try it with a real serial port first... even if that means setting a computer up in your car.
The USB serials dont usually work.. at least not reliably.
I went with a PCMCIA serial port, it works perfect
Old May 7, 2008 | 07:35 PM
flyinZ's Avatar
Where did you pick up that PCMCIA serial port cable at?
Nice sig
Old May 7, 2008 | 10:58 PM
dookie454's Avatar
Got it off ebay super cheap no name brand. Red Chief or something like that? Hard to find drivers for no name cards if you ever lose them.
Old May 8, 2008 | 06:47 PM
flyinZ's Avatar
Now that you mention it, I dont remember a CD driver, that came with the cable...That could be my problem...Would any USB driver work for that? I found a couple on Moates..
Hit up Ebay, and didn't find anything under Red Chief...
Old May 10, 2008 | 01:58 PM
flyinZ's Avatar
I downloaded a USB driver off of the Moates site..the laptop recognizes that the cable is there, but it still says..."no message sent-cable failure", whenever I try and read the pcm. Any help on how to tell whether its the cable or the laptop?
Old May 10, 2008 | 05:36 PM
pcgamer4life's Avatar
More than likely it's not set up to read on the same COM port as the cable is plugged into. Plug it in, make sure it's read properly. Go to start, right click my computer, click manage, click device manager, click COM and LPT ports, and find what COM port your cable is using. Set your programming software to that port... it ought to work then.
Old May 10, 2008 | 09:29 PM
flyinZ's Avatar
Ok...checked all that out, its using port 1..Hooked the USB cable into that port, and nothing....says the same message..Why do I have a feeling my cable is crap..lol.
Old May 24, 2008 | 10:46 AM
flyinZ's Avatar
UPDATE: I found an ALDL test file, and tested the cable. It passed every test that I performed. Set everything up on the right COM port, and it passed! Now the message that Im getting is "No response from PCM", WTH does that mean? Cable not hooked in the port correctly or??
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
