Boost guage tap questions
Old May 6, 2008 | 09:46 AM
Rice Killer87's Avatar
Ive searched and searched and found nothing.
I know I need to drill and tap the intercooler pipe right before the intake manifold for it,but the pieces that came w/ my boost gauge dont look like anything anyone else it using. I have a couple plastic T's and two brass pieces (male and female) where you slide the little plastic line through the female,"jam it" w/ that small oval shaped piece and then tighten it onto the male portion.
Heres a pic:
What do I need to buy for the bigger male fitting to screw on to on the intake?
Thanks for any help on a stupid question!
Old May 6, 2008 | 09:55 AM
c0rey's Avatar
Go to napa and get a brass t and tie it into the intake manifold.
Old May 6, 2008 | 10:28 AM
Forgot to mention this is going on the tow truck,its an '04 Duramax.
Thanks for the info man,will go and check it out.
Old May 8, 2008 | 11:05 PM
OBE1 95Z28's Avatar
Typically folks measure boost in the intake manifold. To do this, just T you gauge tubing into one of the existing intake manifold posts (like where the ERG gets vacuum).
Old May 9, 2008 | 08:01 AM
cause4panic's Avatar
diesels dont build vacuum since theres no throttle body. silly goose
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Form
Feb 10, 2015 11:23 PM
