What is a good set of front brake rotors?
Old Dec 19, 2002 | 06:23 PM
eyeoutthere's Avatar
Question What is a good set of front brake rotors?
I don’t want anything real expensive; just something that works well and will not rust on me.
Any suggestions?
Old Dec 19, 2002 | 06:33 PM
Loudmouth LS1's Avatar
yeah, that's a good question
Old Dec 19, 2002 | 07:31 PM
96SFLZ's Avatar
If you don't want to spend a lot of money then I'd just go with a couple PowerSlots, they're around $100 a piece.
If you want to spend a little more than that, look into the Baer EradiSpeed's. They're about $500 for the front (both).
Old Dec 20, 2002 | 04:14 AM
toykilla's Avatar
Do Vette rotors fit SS's/Z28's? If so, get the Corvette rotor and caliper assembly. You could probably find them at a junk yard somewhere for cheaper and bigger than Powerslot rotors. I'm gonna put Eclipse GSX rotors/calipers on my GS Eclipse. They are like an 1" bigger and the caliper is a lot larger. You might want to check sizes on your big brother.
Old Dec 20, 2002 | 07:36 AM
ShaneS's Avatar
Vette rotors & calipers do not bolt up. LG Motorsports does sell a kit that lets you mount the Vette rotors (& optionally, vette calipers) up front...
Shane
Old Dec 20, 2002 | 08:23 AM
stew w/00&92's Avatar
TireRack sells replacement Brembo rotors for $61 each.I've heard they are very good and don't warp.
Old Dec 20, 2002 | 02:39 PM
chuck's Avatar
I have had very good luck with AutoZone rotors. $38 each and they outlasted KVR blanks 8 times over on the road course.
And yes, C5 brakes will not bolt directly up to an F-body, but LG sells this:
hotrodyou1
Dec 20, 2014 10:05 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
slocody
Feb 10, 2003 01:04 PM
