96-97 Guys:Help finding wiring for pre/post O2 sensor
Old Apr 28, 2008 | 09:05 PM
97WS6Pilot's Avatar
I'm hooking up my rear O2 sensors after removing them 4 years ago. Now I can only find one of the square pin connectors on the main harness. Help me find where on the harness the two rear O2 pig tails are. I found one that comes off the harness near the rear of tranny sensors. Where is the other one?
Old Apr 29, 2008 | 12:51 AM
TeamingTealZ28's Avatar
M6?
Old Apr 29, 2008 | 01:54 PM
97WS6Pilot's Avatar
Yes, M6. Do you know the stock location of the rear O2's and wiring? Thanks in advance. I'm installing them in my dual catted pacesetter longtube y pipe just for fun and doing a little research on the effect on A/F ratio and computer functions.
Old Apr 30, 2008 | 08:45 AM
yungin' w/a z28's Avatar
If your car is the same as mine. They should be up by the passenger side header.
I think the one you said you found is the furthest one back. So the other should be up by the header somewhere.
Old Apr 30, 2008 | 09:18 AM
The after-cat sensor on the driver's side should have originally been on the Y-pipe, right below the cat, which was bolted to the stock manifold. The passenger side sensor would have to be further back, after the passenger side cat.
Old Apr 30, 2008 | 09:25 AM
My bad. I was mixed up. That is where it should be. Up the header a little bit on the driver side.
Old May 1, 2008 | 11:05 AM
97WS6Pilot's Avatar
Thanks guys I will look when I get back in town. I already looked in those locations so I'm worried that maybe in my haste I cut the pigtail off the harness.
The GM parts guys told me that both rear sensors are on the passenger side of the Y pipe. One pre cat and one post cat. I think they are wrong because if that were true then nothing would be monitoring the left bank cat.
Ringmaster72
Dec 12, 2017 10:12 PM
cmdeshon
Jan 4, 2015 11:15 AM
Queens94z28
Dec 20, 2014 09:11 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Jul 4, 2005 05:00 PM
