how hard would it be to...
Old Apr 28, 2008 | 12:51 AM
tastyZL1's Avatar
swap my lt1 with a ls1, what all do i need....my buddy has a extra ls1 laying around with 55k miles and is willing to give it to me... i know i should search this but its 2 am and i wanna go to bed.... thanks everyone
Old Apr 28, 2008 | 09:38 AM
Kraest's Avatar
Retired
You'll need an LS1 PCM, wiring harness, figure out a way to drive all of your LT1 gauges, etc. Not exactly an easy thing to do, but not terrible.
Old Apr 28, 2008 | 11:10 AM
RE AND CHERYL's Avatar
It's an easy swap but will require a lot more then just the engine. You will also need to either modify the LS1 harness to plug into the LT1 harness, or pay to have it done. Here is a quick list of what you need.
1 engine with harness and PCM (harness MUST be modified)
2 k member with P/S rack (LT1 rack won't clear LS1)
3 LS1 transmission (your LT1 tranny will not work)
4 modified fuel lines and regulator or 97 Vette LS1 fuel rail
5 LS1 heater hose assembly
6 Exhaust modifications
7 PCM programing
There are many other small items you will need but this is a short list. I would advise you to do your research upfront to minimise down time. I would also check out LS1TECH.COM, they have a conversions forum you will find invaluable.
Re'
Old Apr 28, 2008 | 01:34 PM
tastyZL1's Avatar
thanks guys
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
