Cutout Wiring
Old Dec 19, 2002 | 10:41 AM
silverbullet02's Avatar
Exclamation Cutout Wiring
What is the cleanest way to wire up an electric cutout. I know I have to bring back a power and ground wire to it. Do I need to run two wires all the way back from the battery?? Also, where is a good place to mount the switch in an '02 Camaro.
Old Dec 19, 2002 | 11:10 AM
2001NBMZ28's Avatar
Route the wires through the plug under the rear seat, under the carpet, under console, to the dash. I don't have ASR so I used the ground from the cigarette lighter, then ran a wire under the dash to the radio fuse for power. I bought a convertible bezel cover from the dealer and installed the switch on it.
Old Dec 19, 2002 | 11:16 AM
GoFast908Z's Avatar
Member
I mounted my switch to the bracket that holds the driver's seat. ITs on the left side, to turn it on just reach under and there it is. Hidden nicely.
Old Dec 20, 2002 | 08:25 AM
What is ASR??
Old Dec 20, 2002 | 08:59 AM
2001NBMZ28's Avatar
Acceleration Slip Regulation - Traction Control. If you have it you can use the pink wire to the switch for the power connection.
Old Dec 20, 2002 | 09:36 AM
How do I know if I have ASR?
Old Dec 20, 2002 | 09:38 AM
Never mind. I tend to do a bit of tire shredding and never notice the car try to correct it, and there is no light in the cocpit that says I have ASR disabled (I guess it would, as my 2001 Impala did).
Old Dec 20, 2002 | 10:55 AM
ExMustangOwner's Avatar
Could someone explain this a little more in depth? I understand wiring under the rear seat then to the console but from there I'm kinda at a loss. How do you wire the switch and what wires to tap into?
Old Dec 20, 2002 | 12:59 PM
2001NBMZ28's Avatar
The electric cut out comes with the switch already wired. The harness (near the switch) will have 2 wires coming from it. One wire goes to a ground, the other to a "switched" power source. Sounds confusing but it's an easy install. I got mine from www.quicktimeperformance.com I had a question when I installed mine, called them, and got great customer service.
BLK1997Z28
May 7, 2015 03:01 PM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
lbrowne
Nov 13, 2011 04:25 PM
