Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Wiring/Testing a relay
Old Apr 22, 2008 | 05:51 PM
mdacton's Avatar
I have a relay with 5 wires for my fuel pump. Its the fuel pump relay that come with the DFI. I have it hooked to a switch on the power side going to the pump so I can cut the pump off...but the relay will still be powered.
Will this burn up the relay?
How is it wired and how would I test one? I searching for how to test it and had no luck for the most part. But I think it is bad I swapped relays and it works fine. But want to know how to check these for future ref.
Numbers on the top
Omron
25553347
Z-7365
Side
a3129
has 30 87 87a 85 and 86 on the diagram....
Old Apr 22, 2008 | 05:59 PM
mdacton's Avatar
I found this...the 5th wire is confusing me.
Old Apr 23, 2008 | 12:56 PM
Courtesy of Brent Franker...
The extra terminal is for use in making a connection when the relay is not energized. It gives you another option.
Aaront810
Aug 29, 2020 09:34 PM
OutlawPerforman
Oct 30, 2017 05:40 PM
Jeff1904
Jun 5, 2016 05:00 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
jerrysims71
Aug 15, 2015 12:47 PM
