Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
opti is bad
Old Apr 21, 2008 | 09:19 PM
jtarp's Avatar
opti is bad
My car has been missing when you give it too much gas. I took it and got it scanned for codes etc... and i found out that it is the opti. How do i know if i need to replace the whole thing or just the cap and rotor?
Old Apr 21, 2008 | 10:27 PM
The Opti only sets two codes - DTC 16 and DTC 36 - and both of those are for the optical sensor. There are no codes directly related to the high voltage side (cap/rotor). Which code did you get? They can also be set by a corroded harness connector.
HectorM52
Jul 30, 2017 11:46 AM
beltrunner
May 17, 2015 10:18 PM
BLK1997Z28
May 7, 2015 03:01 PM
rocknroler69
Apr 29, 2015 10:24 PM
ad356
Apr 11, 2015 10:30 PM
