msd window switch(A4?'s)
Old Dec 18, 2002 | 07:42 PM
funina91ss's Avatar
I was wondering if running a widow switch on an A4 car would slow down the et. if you had it shutting off between shifts?To save tranny life.Thanks Sean
Old Dec 19, 2002 | 04:54 AM
94DROPTOPZ28's Avatar
Good question I'm really interested in the answer to this one, I'm getting ready to put spray on my A4
Old Dec 19, 2002 | 08:07 PM
MonoxideChild's Avatar
Same here. Very interested.
A4 Sprayers Where are you?
Old Dec 19, 2002 | 10:35 PM
95 Mystic TA's Avatar
I will be an A4 sprayer soon as I get a few of my other goodies together including the window switch. I'm curious also but regarless I will be running one.
Old Dec 19, 2002 | 10:48 PM
Loadre's Avatar
If you lose anything I doubt it would be noticeable. The system is deactivated 100-200 RPM before shifting, then the car must get back in the window and the system will reactivate. Since most normally finish in 3rd, that means the system will not be spraying for a whole 200-400 RPM. It all comes down to how bad you want that extra .05 and how soon you're willing to rebuild your tranny.
Old Dec 20, 2002 | 10:05 AM
RacinLT1's Avatar
I spray through the shifts,and dont run a window switch,so i cant help you there.
I had my trans rebuilt last feb,beat the crap outta it this past season,and fluid looks great still.
Old Dec 20, 2002 | 11:43 AM
T/A lt1's Avatar
I can't give you a number but it does go faster spraying thru the shifts. I don't know if it's worth it b/c I am rebuilding my 4l60e again but I have tried it and p/u et in the 1/8th so I am sure it helps and if the trans is built right it should hold it.
Old Dec 20, 2002 | 07:36 PM
funina91ss's Avatar
well I am do for a trans rebuild anyway the car has 104k on stock motor and trans.Shifting on the juice is just a little funny felling not a fast firm shift.NA it shifts fine.
Old Dec 20, 2002 | 11:23 PM
crazyjoe's Avatar
Hmmmm,
That sig looks VERY familiar!!! LOL
Good luck with the car Sean, I hope you have as much fun as I had with it!! Get the window switch if you plan on spraying the crap out of her, get it for me, I couldnt stand to see her suffer lol!! I cant wait to see my girl in the 10's!! I know you'll have her there!
Looks like I've got a LOOOONG way to go with this '91 to catch back up with you guys now, give me time, it will be done!!
Later.
Joe.
Old Dec 21, 2002 | 01:18 AM
funina91ss's Avatar
Thanks Joe I have been taking it easy on her so far, to loud to get to roudy with her.
Old Dec 21, 2002 | 06:15 AM
1QUIKTA's Avatar
Sean, well you stole his car and now his sig. Are you going to take the pics from him as well?
Joe, so the 91's name is Ruby is it. I have a feeling she will be surpassing me in no time and catching up with the 95 in the future!!
Old Dec 22, 2002 | 12:07 AM
crazyjoe's Avatar
Yeah, good 'ole Ruby!! I'm going to get the appearance of her straightened out right off the bat. I figure it will be a while before I sink any money into the engine (definately going with something bigger, if I had it to do over again I would've found a 350 in the beginning!!! Lousy 305!) I've been thinking maybe something along the lines of a ZZ4 crate motor or similar, just an idea, we'll see when the time comes............if I still own the car lol!
And Sean can "steal" my pics too if he wants, all they're good for to me is making me cry I've got some decent pics of the nine-five with the WS6's on her, I'll have to give 'em to him to scan. Later.
Joe.
Old Dec 22, 2002 | 10:57 AM
George Debski's Avatar
You will definitely lose ET by not spraying through the shifts. I gained 3 tenths and 3 mph spraying 100% through the run with no other changes.
I went from 1.8lbs per run to 2.2lbs per run. I have a TH400 with manual valve body. I would NOT advise it with the 4L60E.
Old Dec 22, 2002 | 01:02 PM
Spyral's Avatar
I run a window switch and just got my car back with a really stout rebuild and converter. I havent sprayed it yet, but I will tell you how it goes! I have it come in at 2500 and run out to 6000. Now, that was before the converter, 2800 stall, so I don't know if I have to adjust it or what. Actually, does anyone know if I should adjust it?
Old Dec 22, 2002 | 11:04 PM
GhostZ's Avatar
At WOT, you'll probably be stalling around 3K. You can leave the window switch set where it is, the stall will only help to constantly keep you above the 2500.
