how bad is an out of balance driveshaft??
Old Apr 18, 2008 | 03:43 PM
JMG97SS's Avatar
I just put in a LS1 driveshaft and Im getting a roaring sound that seems to just be there if I accelerate up to 70-90 and let off and let it coast, just letting the car hold its self back. Also crusing around 70 I get it alittle noise. Im not getting much vibration that I can feel but if its the driveshaft balance can it hurt anything running like this?
Old Apr 18, 2008 | 03:44 PM
b.lee's Avatar
Check the rear end where the drive shaft connects to it.
Make sure it does not move in around.
(I think you might need some rear end adjustments or bearings.)
Old Apr 18, 2008 | 04:53 PM
JMG97SS's Avatar
what adjustments do you mean what bearings? I have 4.10 gears going in May the 2nd so the pinion bearing I guess will be changed then
Old Apr 18, 2008 | 10:00 PM
JMG97SS's Avatar
Ok I put the stock shaft back in with a new rear u joint and Im still getting the roar so I stuck the LS1 back in with a new rear U joint still have the noise. One question, the stock shafts old rear U joint would barely swivel from side to side, the new one swivels freely. Is it suppose to move freely or be kinda stiff? Im begining to think its the rear wheel bearing or the rear end.
HectorM52
Jul 30, 2017 11:46 AM
eanhl2004
Apr 4, 2015 12:01 PM
blac94Z
15
Mar 2, 2015 12:00 PM
ddr698
Jan 31, 2015 10:58 AM
