GM 847 and nitrous
Old Apr 16, 2008 | 07:06 PM
LSWHO's Avatar
GM 847 and nitrous
Would these pair up decently? I was just wondering. I know nitrous cams are set up a certain way.
Old Apr 17, 2008 | 09:11 AM
MichiganSkip's Avatar
Seems like OneFlyn95z28 ran that cam with nitrous and did pretty well with it.
Old Apr 17, 2008 | 05:31 PM
Steve in Seattle's Avatar
Seeing how I have Ellis's 847 cam in my 396... with nitrous plans, I'd say it's "ok".
Most N/A cams are a good place to start for N2O. Nitrous-dedicated motors however will benefit from increased EXHAUST duration, and by moving the opening and closing times forward (via increased lobe separation... say a stock-looking 114 or 116 degress).
More overlap isn't so much a problem, nor is less intake lift/duration... it's mostly about exhaust timing.
The 847 is fairly good on both accounts. exhaust duration is quite long, and moved forward almost 10+ degrees over stock. The exhaust lobes also have a good amount of lift, but you could put 1.5RR's on it if needed.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
