Centerforce Clutch and High Rpms
Old Apr 9, 2008 | 07:24 PM
corvet786c's Avatar
Shifting seems to be ok during normal driving, but when I get pass 6000 rpms I cannot shift. Anyone else have this problem and what could it be. I tried searching and some said to get flywheel balanced. Need advice thanks
Old Apr 10, 2008 | 12:42 AM
mzgp5x's Avatar
quite some time ago gm high tech mag had an article on "thunder-chicken" (a 1995 trans-am) M6 with a centerforce. They changed to a Spec. The weights on a centerforce cause a problem with the 2 to 3 gear transition due to the LT1 tight design clearances in the clutch pack. With higher rpm, the weights apply additional load on the pressure plate and close the clearance so the clutch disc will not completely dis-engage. Possibly tou could find the mag article on their website. This was the reason I went with a SPEC. There are other clutch units of equal quality. Hope this helps you. B,
Old Apr 27, 2008 | 12:20 PM
JP95ZM6's Avatar
My CF DF would shift fine above 6500, while it lasted. Maybe you have a little air in the hydraulics, giving you a little less travel than mine and making the difference? Or maybe my clutch disk was already thin enough to give extra clearance by the time I got to shifting that high.
If you haven't figured this out yet, try bleeding it.
Old Apr 28, 2008 | 11:18 PM
corvet786c's Avatar
Thanks Guys The problem I was having was my master cylinder. I bought a Ram Adj Master and now I can shift to 6000+ rpms. The Adj Master Worked.I am very happy now I can finally shift.
Old May 3, 2008 | 12:00 PM
95*DropTop's Avatar
Center Force DF
I have a question did you guys use your stock flywheel with the clutch to line the clutch to balance it out cause I bought a new flywheel and the clutch instructions says to line the yellow paint dab on the clutch to the x mark on the flywheel well only the stock flywheel has a x mark on it and I installed mine yesterday and i have a little vibration so now i have to take it all apart again!!!???
timmy39120
May 2, 2015 05:12 PM
BigWil
Mar 29, 2015 12:24 PM
HectorM52
Jan 30, 2015 11:08 PM
Chrisdude
Aug 14, 2002 06:30 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
