AN to cut steel fuel lines?
Old Mar 26, 2008 | 10:14 AM
Tricked-Out-Toy's Avatar
Ok so I was looking thorugh Summit for AN fittings that I could use to connect to my steel fuel lines and the only think I could find that didnt require flaring was aluminum piping. is there something out there for steel? I dont want to flare the line so a slip fit is a must.
Old Mar 26, 2008 | 12:15 PM
mdacton's Avatar
hardline adapter with a compression fitting.
The 3/8" one is easy to find......only one company makes the 5/16" one...forget who it is, summit has them both
Old Mar 26, 2008 | 12:46 PM
I must be retarded cause the only hard line adapter I found was one for aluminum lines. does the adapter have a compression fitting on one side and a AN fitting or NPT fitting on the other? I was hoping to find something with a compression on one side and AN on the other..... still looking...
Old Mar 27, 2008 | 10:12 AM
White Lightning's Avatar
russell part numbers are 640850 and 640860, the 850 are the 3/8 and on backorder till monday
Old Mar 27, 2008 | 10:31 AM
Nope sorry dude, those are for the OE fuel lines. I need something with a compression fitting instead of the spring lock. Im using this on a straight cut piece of piping.
Old Mar 27, 2008 | 12:10 PM
mdacton's Avatar
Did you even look dummy?
Don't matter if its steel tube it will work
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 27, 2008 | 12:26 PM
Ahh looks like te second link you posted is what I need. the first one SPECIFICLY says ALUMINUM tubing.... not willing to risk sealing it on steel tubing. thanks for the help Im not a Dummy just blind
87Aerocoupe
Mar 20, 2015 01:23 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
