Pass-Key & Key Bypass (shoebox's Diagrams)
Old Mar 13, 2008 | 03:13 PM
JustNO's Avatar
We try to put an LT1 into another car, but we have some problems. Everything looks okay, but when we try to start the engine, injectors don't work. I think its because VATS right? The problem is there is no Vats module, so its impossible to do bypass trick. What can we do to solve this problem?
Second thing, here it says its needed 2.5 volts:
But in other diagram it says 5 volts:
Should we use 5 or 2.5 volts ?
Thank you
Old Mar 13, 2008 | 04:31 PM
Originally Posted by shbox.com
Purchase a bypass module or have the computer reprogrammed to ignore the need of the signal from the TDM [BCM] (to allow fuel to the injectors)
A bypass module is not the resistor trick. It is a little box that simulates the modulated ground from the TDM (or BCM). You can find them on Ebay (example). Anyone that uses the PCM with an LT1 and transplants it into another car has to do this or have the computer reprogrammed.
Old Mar 13, 2008 | 04:41 PM
JustNO's Avatar
Thank you. And for my second question ? it should be 2.5 or 5 volt ?
KYWes
Jun 14, 2022 06:52 AM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
colts0455
Sep 2, 2015 12:41 PM
4586
Aug 18, 2015 07:08 AM
