edelbrock LSX heads
Old Mar 7, 2008 | 08:54 AM
jmmullin's Avatar
edelbrock LSX heads
Havent heard ANYTHING about these; and my search for edelbrock cylinder heads brought up everything LT1 related...the main reason I am asking is because Advance Auto Parts sells them, which is where my brother works, which is why I get a 20% discount.....
600/head Xs 2 heads = 1,200 Xs 80% (.80) = $960
1200-960 = 240 = oil pump/timing chain that is also needed...
So thats my logic behind my question; I would assume that by the cheaper price, they probably aren't much better than stock ones
Old Mar 7, 2008 | 09:41 AM
JakeRobb's Avatar
Super Moderator
With an appropriate cam, I believe the Edelbrock heads are good for well over 400rwhp.
There's no question that there are better heads out there, though.
Old Mar 7, 2008 | 09:46 AM
jmmullin's Avatar
thanks; how about reliability? doesnt matter if i only spend 1000 or 3000 on heads; i really want them to be reliable more so than powerful... just got my FAST intake and throttle body today so the parts are going to start trickling in dependent upon my credit limit haha; i've still got at least a month before i will be buying the heads...still researchinggg
Old Mar 7, 2008 | 10:16 AM
JakeRobb's Avatar
Super Moderator
Not very many guys around here running the Edelbrocks, so I can't guess at reliability. I'm sure Edelbrock will take care of you if something goes wrong, though.
Personally, if I were getting heads, I think I'd look into a set of ported L92s.
Old Mar 7, 2008 | 11:00 AM
Marc 85Z28's Avatar
Judging by what I saw at the Edelbrock stand at Maple Grove last summer, those heads appear to be lacking compared to most other aftermarket castings (like ALL Edelbrock heads). The as cast cylinder head on display looked terrible - ports were tiny - like samller than 170cc. The ported version they had next to it didn't look impressive at all. I have no idea what kind of power they make though
Old Mar 8, 2008 | 05:33 PM
9T8W66's Avatar
Not for a 346
Old Mar 9, 2008 | 08:22 PM
JakeRobb's Avatar
Super Moderator
Originally Posted by 9T8W66
Not for a 346
Good point. If I were getting heads, I'd be going big-inch at the same time.
Old Mar 10, 2008 | 08:01 AM
teke184's Avatar
if they are the ones listed in summit racing...they only advertise a 270/200cfm flow at .550" lift.
hell you can have closer to 300cfm from some $1000 ported factory castings.
Old Mar 10, 2008 | 10:07 PM
Bayer-Z28's Avatar
^LQ9's flow close too AFR/TF heads!! About $1200 fro two assembled..
Old Mar 11, 2008 | 06:32 AM
jmmullin's Avatar
one guys says to get LQ9's, then another guy says not for a 346 (which is what i have..) then the other guy says go 'big inch' then another guy says go with LQ9's haha so is the LQ9 for the 346?? and does big-inch mean go with a bigger combustion chamber...but wouldnt that make less power? or what does big inch mean.. thanks for the help
Old Mar 11, 2008 | 07:31 AM
dangalla's Avatar
lq9 heads will not fit on your car, the bore is different. if i were you i would go with ported ls6 heads
Old Mar 11, 2008 | 07:33 AM
jmmullin's Avatar
THANK you. i believe i will go with the PRC 2.5 ls6 heads whenever i pay off the current credit card bill
Old Mar 11, 2008 | 07:46 AM
teke184's Avatar
um...pretty sure "big inch" is refering to boring and stroking. not the heads.
what cam are you wanting to run? that will determine what the best head is for your application.
my only issue with some of the ported ls6 heads are that some have BIG intake runners...which will kill low/mid range...but give you a nice dyno queen.
more info please
Old Mar 11, 2008 | 07:49 AM
jmmullin's Avatar
more info please
looking at the 224r or 228r since i will probably get one of the packages from texas-speed... what do you think about the torquerv.2 or new v.3? they looked like they were a little bigger than the 228; but since i want to drive it whenever the weather is too bad for my bike i'd like it to be pretty small-mild for drivability...400+whp
Old Mar 11, 2008 | 08:10 AM
JakeRobb's Avatar
Super Moderator
Correct. Are you responding to me? If so, you've misunderstood. Go back and read again.
