10" or 12" sub???
Old Dec 15, 2002 | 06:55 PM
My90Iroc's Avatar
10" or 12" sub???
I'm looking into getting a new sub for my trunk in a truck box so I can have a little more room in my trunk. Right now I have a 10" bazooka-style bass tube which basically takes up the whole trunk. My question is will I be happier with a 10" or 12" sub? I listen to metal so I need the sub to bring out the drums which have sharp and abrubt beats rather then say rap/r&b type music where the bass is more drawn out. The tube I have now does a pretty good job of bringing out the double bass notes and such, but if I can keep the sharpness and clarity and get a little more punch with a 12" sub I'd go with that. Please advise and also feel free to make suggestions about brands of subs, lots of people seem to be happy with JBL. Thanks.
Old Dec 15, 2002 | 07:26 PM
ibanez6rg's Avatar
I would recommend 10s for you. With 10s you'll get tighter bass and a better response. This will probably be better for your music selection. It's also cheaper. Seeing how you're not a bass head, you won't need to spend all the extra money for a good bass system.
Old Dec 15, 2002 | 08:12 PM
Billy Badass's Avatar
From: Carbondale, Illinois (home) Champaign-Urbana, Illinois (school)
Hey man... it doesn't sound like you're a bass freak so a 10" should do wonders. As far as tighter sounding bass, there shouldn't be too much difference between a 10" and a 12". It really depends on the box, and if you're getting a truck box it probably will be completely sealed so that should give you tight bass. If the box is ported, then you'll have a lot more "rolling" bass which you sound like you want to avoid. My guess would be a 10" in a sealed box should do fine.
-Bill
Old Dec 15, 2002 | 09:15 PM
firebirdude's Avatar
Sounds like you're a prime canidate for a stealthbox! It's a small sealed box that can fit on either the driver's or passenger's side. It fits right where that plastic side panel is. Makes use of otherwise un-used space!!! You can still use your WHOLE trunk area!!! JL and MTX make them.... but I recommend checking out www.subthump.com Try a JL 10W3v2 sub in it.
Old Dec 15, 2002 | 10:16 PM
My90Iroc's Avatar
Damn, that's awesome. I'll definitely be considering that. Thanks for the help guys.
