lt1 posi fit a ls1 housing?
Old Feb 23, 2008 | 10:59 PM
RobZ's Avatar
Need to know if there would be any issues running a lt1 posi unit on a ls1 housing.Considering buying a lt1 posi with gears,but wanted to know what differences are in the ls1 posi over the lt1.
Old Feb 24, 2008 | 08:23 AM
AL SS590 M6's Avatar
Moderator
A 10 bolt is a 10 bolt.
The things that you have to worry about;
is the axle spline count the same? It has to be the same as yours.
does either one have an ABS reluctor ring? If your old one does then the new one needs to have one too. If yours doesn't then it doesn't matter whether the new one has one or not.
Old Feb 25, 2008 | 02:28 AM
RobZ's Avatar
I have a 2.73 2 series carrier with abs,but im not sure what the spline count is.Anyone know?
Old Feb 25, 2008 | 08:55 AM
IIRC, stock is 28 splines.
Old Feb 25, 2008 | 03:41 PM
RobZ's Avatar
So are the lt1 28 splines just like the ls1?I need to find this out?thanks
TitoPR221
Jan 29, 2015 08:00 PM
ddr698
Jan 9, 2015 10:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
