Knock on startup?
Old Sep 11, 2002 | 07:15 AM
Lions3's Avatar
Post Knock on startup?
When I start my car, I sometimes get a small knock. It'll sound like..
Crank crank knock VROOOOOOOM idle idle idle
The engine runs like butter though. No stumble, no misses right through the power band and nothing else to complain about. I only get this knock on startup, and even then it's only sometimes. Any ideas?
PS no codes.
Old Sep 11, 2002 | 02:26 PM
usem's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Lions3:
PS no codes.
</font>
How many miles are on your engine?
What type of oil and filter are you using?
TTT for you.
-Mike
Old Sep 11, 2002 | 02:33 PM
moparman's Avatar
Post
I've heard Fram oil filters can cause this.
Old Sep 11, 2002 | 02:43 PM
MisterGuru's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by moparman:
I've heard Fram oil filters can cause this.</font>
From what? A bypass valve?
Sounds like it may be starter/flywheel related... if the pop or knock is just when cranking, not running.
-- Tim
http://tim.mindriot.net
Mods:
58mm TB, 30# Accel Injectors, GMS MAF, Meziere Water Pump, March Pulleys, LS1 Alum. Driveshaft, 3" cutout, BTE 3600 stall, TH350 with TCI Transbrake, B&M Pro Ratchet, Moser 12-bolt with 33 splines & spool, MAC Torque Arm, Dynatech headers, Homemade Y-Pipe, Edelbrock "cat"-back, XE230/236 cam - click to hear!, CC 1.6RR's and guides, Nittos, MSD 6 Digital+, Accel Super Coil, Hurst LineLock, Eibach Drag Launch Springs, KYB adj struts, CE Drag Shocks, Lakewood LCA's, Biondo Mega 75 Delay Box, 3.73
<A HREF="http://www.shootmyphoto.com/misc" TARGET=_blank>
Best Times: 8.10 1/8th mile, 1.750 60', 87 MPH</A>
Why not to buy from RACENETclick here
Old Nov 27, 2002 | 01:21 AM
Ws6Envy's Avatar
same problem.....any more ideas????
Old Nov 27, 2002 | 01:42 AM
Donny O's Avatar
same thing with mine. I always assumed it was jsut the force of it firing and starting up with no initial oil preasure adding to it.
Old Nov 27, 2002 | 07:24 AM
moparman's Avatar
It has been noted on this board that Fram filters can cause a knock at start up. If you have a Fram oil filter, try changing to better filter. Just do a search for oil filters and you'll find out more than you want to know.
Old Nov 27, 2002 | 10:19 AM
Ws6Envy's Avatar
i use ac filters.....i am really concerned with this knock sound......should i be?
Old Apr 3, 2003 | 01:14 PM
3.1firebird's Avatar
I searched in the archives and came across this old thread, but my 94LT1 does the same with 135k and an AC oil filter. Small knock only on startup, I can hear it sometimes when I shut it off.
Let's hear some more idea's....
Old Apr 3, 2003 | 01:35 PM
Lions3's Avatar
Woah. Bring this one back from the dead
I since traded that car for a 94 TA, and it does the same thing. No problems though.
Old Apr 5, 2003 | 05:25 PM
yea this thread was pretty much a buried and decaying corse
I guess I will quit worrying about it. If it breaks one day it breaks.
Old Apr 6, 2003 | 01:28 AM
chasmanz28's Avatar
i get the knock to but only in the cold months and how can the oil filter cause that knock even though i use gm filters
Old Apr 6, 2003 | 04:39 AM
chasmanz28's Avatar
any ideas
Old Apr 8, 2003 | 05:39 PM
Donny O's Avatar
any ideas
have you ever heard a car right at first startup after an oil change?? usualy their is no oil in the filter and it takes a few seconds to fill it and build preasure and the engine will knock for a few seconds.....this is what people are talking about if the filter not holding oil/preasure.....after the oil goes into the filter it goesinto passages to get around in the engine....after you shut the engine off if the oil all drains back into the engine then it will also take a second to build this back up.....that make sence?
Old Apr 8, 2003 | 05:49 PM
Lions3's Avatar
Makes sense, but the engine build pressure while it's cranking. And any shop that does an oil change should be switched on enough to fill the filter up as well.
To me, it sounds like it knocks when it first makes ignition. So it isn't when the flywheel is first engage by the starter, and it isn't once it has hit idle.
It only makes a knocking sound when it's burning up all the accumulated fuel.
Doesn't seem to be hurting anything, or get worse, but it's sorta annoying.
