dropping car with mac springs...help with front needed
Old Dec 14, 2002 | 04:16 PM
stik6shift98's Avatar
how do i do the fronts...... seems quite impossible
thanks
Old Dec 14, 2002 | 05:00 PM
mdw9965's Avatar
The front struts need to removed before the springs can be changed. The struts come out pretty easily - upper a arm and all. Once the struts are out you can rent a spring compressor or have a shop swap the springs. It is alot easier with pneumatic tools. If you have never replaced a spring on a macpherson strut before it may be better to let a pro do it. Springs can be deady of they cut loose.
Old Dec 14, 2002 | 05:20 PM
that sux......how much do u think it will cost
Old Dec 15, 2002 | 09:54 AM
mdw9965's Avatar
I would guess 1 hour at the going shop rate like $75-100 if you brought them the struts out of the car already. If your lucky you might find a shop that will do it for 1/2hour labor because thats about how long it really takes.
Old Dec 15, 2002 | 02:32 PM
wow..i was quoted 150 for everything
Old Dec 15, 2002 | 02:37 PM
ratio411's Avatar
$150 is a good price if they take the shock/spring assembly out of the car and put it back.
You will also need an alignment when you lower the car.
If you are set on doing it yourself, you can look at page 6 of my website... I have some info that might help you.
Good luck
Dave
Old Dec 15, 2002 | 03:04 PM
sweet..... thanks.......ya i got a buddy that will align it at a tire place
blown94
May 3, 2015 12:48 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
