Idle skip/miss
Old Feb 4, 2008 | 02:50 PM
DaddyLover's Avatar
Idle skip/miss
I did search! i couldn't come up with anything or might of not used the correct wording. My car is stock basically has a lid since ive had it, it doesn't have a problem missing underload or uptop but at idle i will have alittle miss/skip involved with the shifter shaking with the miss or skip obviously no codes for it but is this normal
Old Feb 4, 2008 | 10:05 PM
Kraest's Avatar
Retired
Sounds a little normal. When's the last time you did a full tuneup and how many miles are on the car?
Old Feb 6, 2008 | 09:13 AM
AL SS590 M6's Avatar
Moderator
As was pointed out to me a few weeks ago by another member here, GM put out a TSB stating that there is a new Delco Iridium plug with a .040 gap that is suposed to clear up the idle miss that all LS1s have.
Just for fun I went into Advanced Auto and asked what their book showed for a Delco replacement plug for our 98 SS and he came out with the new plug. But they are about $8 per plug.
Old May 2, 2008 | 07:39 AM
NEWBIE T/A's Avatar
Question Back from the dead ! Similar issue, though.
I just had the plugs changed by the same mechanics that have done it twice before. NGK plugs, not sure what the gap is , and the stock coil wire were replaced w/ MSD's ( ) the 1st time around - say 32K.
Car has 93K on it now.
I now am experiencing what I will call a "hard miss" at idle - meaning that when it does this, it is noticeably different than just the usual mildly lumpy idle . Like the engine died for a brief second , then came back to life.
Stock engine internals , Borla catback on it since I bought it in '01 w/ 24K on the car - basically, nothing has changed other than the plugs and this was not happening before.
Think it could be a bad plug ? The car runs fine other than an occasional surge feeling when taking off from a stop.
No SES light , either.
Thanks !
Britt
Old May 2, 2008 | 08:51 AM
Moderator
Clean the IAC, TB, and MAF.
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
