Lowered camaro
Old Feb 4, 2008 | 12:21 PM
kyle67camaro's Avatar
Lowered camaro
I have a 98 camaro z28 and I am getting some 18's on the front and 19's with 315s on the back. I know the couple little mods I need to do to fit those on my stock suspension, but I am wondering what I will have to do to drop it 1.2 inches.
Old Feb 4, 2008 | 01:09 PM
Lowering springs.
Old Feb 4, 2008 | 02:06 PM
rLyTa1n's Avatar
I would go for a nice set of KYB or Koni shocks and then get the lowering springs, just adding lowering springs without a nice set of shocks can make the car look good but it will handle sloppy because of all the geometry being off. Depending on your budget get yourself some nice lower control arms and the lower control arm relocation brackets at least to help with the geometry of the suspension being lowered. Hope this helps alittle bit, take care.
Old Feb 7, 2008 | 05:38 PM
87BlackZ's Avatar
I upgraded to Eiback lowering springs with a 1" drop, Spohn rear control arms and panhard rod and KYB front struts and rear shocks.
The car handles great and can take sharp corners without a lot of body roll or flexing.
Old Feb 7, 2008 | 09:27 PM
slomarao's Avatar
you need lowering springs to lower the car. The spring is responsibile for how high the car sits.
I would talk to Sam strano or strarnoparts.com.
Old Feb 10, 2008 | 09:12 PM
Cool ZR's Avatar
I second that, Sam is great to deal with and only sells you what you need. I did his suspension package 4 and am very happy with the results. Definately get a set of his swaybars, they make a HUGE difference in the feel of the car.
Old Feb 11, 2008 | 11:44 AM
EvilBird's Avatar
Anybody hear running Eibach Sportlines or Ground Control coilovers?
Old Feb 11, 2008 | 11:57 AM
Cool ZR's Avatar
My car had a set of Eibach's on it with the DeCarbons and I swapped those in favour of a set of Koni adjustables with Strano springs. I like the ride better myself, but it wasn't as big a difference as I was anticipating. I still have to play with the settings on the shocks though. The biggest thing is these parts are matched to each and work well together so you get a better ride quality. The Eibachs I am told are too much spring for the Decarbons.
oldschool
Feb 9, 2016 09:21 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
