Hard Accels = ABS Inop light = no traction control / Very odd
Old Dec 12, 2002 | 10:22 PM
thelemur's Avatar
Unhappy Hard Accels = ABS Inop light = no traction control / Very odd
Ok, under hard acceleration, my ABS INOP light comes on. When this happens, the traction control will not engage.
Im wondering if its related to the problem I have where when it gets cold out, and I go WOT, the pedal feels like it has a slight pressure back at me, almost like the trac control does when its in use (but not nearly as firm).
Any ideas?
Old Dec 12, 2002 | 11:30 PM
BlackDog's Avatar
Sounds like a loose connection some where. I think there is a sensor on top of rear axle in the center and at each wheel. Take them apart and make sure the connections are clean. Any time the abs light goes on and off is usally due to a bad connection not the abs unit it's self.
My guess is the sensor on the axle that's where any movement would happen under hard take offs.
Also traction control and abs are tied together, if one doesn't work the other won't ethier.
Old Jun 19, 2003 | 03:19 AM
107's Avatar
107
I know this is an ancient post but was wondering if you've solved the problem or if anyone else has ideas!
The same exact thing causes my ABS light to come on! Except GM scanned it and they said it was throwing the code for RightFront Speed sensor. I wonder why accelerating hard would set it off?
BTW I dont have traction control.
Old Jun 19, 2003 | 07:37 AM
thelemur's Avatar
Nope, I still haven't solved my problem. But then again, I don't know where the ABS sensors are to check them out.
Old Jun 19, 2003 | 09:28 AM
jim88iroc305's Avatar
Cool
Check driver side front wheel and the rear end pumpkin for ABS sensor locations.
Old Aug 8, 2003 | 10:53 AM
Se7ix's Avatar
Wow. I'm surprised that other people have the EXACT same problem as me. Under accel, the abs inop light comes on and then braking feels different (obviously, since abs isn't working).
I have read that there are noted problems with the abs motor in the LT1, particularly in humid, hot environments (I live in Florida).
However, (and most peculiar), the ABS computer should NOT engage unless 1) wheel sensors reporting near lock-up 2) brake switch is closed i.e. brake pedal pressed. It doesn't make sense for the EBCS to be engaging the brakes under heavy accel given that your foot wouldn't be on the brakes.
I intend to do some playing with it this weekend and will report my findings. You all do the same please. I will start with attempting to disconnect / disable the ABS altogether to see if it fixes the terrible accel my car experiences. If the car accels faster, I know the ABS malfunction is causing my performance problems.
At any rate, I'll post whatever I figure out.
Keep this post alive folks...!
Old Aug 8, 2003 | 10:57 AM
94formulabz's Avatar
If they have traction control the pumpkin won't have a 3channel system sensor on it. They have a 4 channel system so the tone rings are on the ends of the axles instead of 1 on the ring gear.
-brent
Old Aug 8, 2003 | 11:37 AM
TobyZ28's Avatar
I have the exact same problem as well.. Floor it, abs inop lights on
Old Aug 8, 2003 | 01:06 PM
Se7ix's Avatar
I read on another post that plug wires close to the abs wires on the shock tower can also cause interferance (likely given this happens under accel). I recently installed shielded Accel Ex 9000 plug wires. The problem existed before though.
Anyone also experience sluggish performance before the abs inop light comes on?
Old Aug 8, 2003 | 02:13 PM
BlownF1's Avatar
Also check the ground lug on the passenger side just past the big red plastic power block. My ABS INOP and AIRBAG lights were affected by that ground.
Old Aug 9, 2003 | 12:33 AM
TobyZ28's Avatar
Well i think you're referring to the post i made bout the plug wires close to the abs.. but now its happening again =/ I'm going to go under again and see what i can find out, I think its still fairly close... I'll check my grounds as well too.
jj_burchiel
Mar 21, 2015 12:51 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
ddr698
Jan 9, 2015 10:05 AM
