What head upgrades are needed?
Old Jan 24, 2008 | 05:46 AM
RUNMYTA's Avatar
Question What head upgrades are needed?
What parts do I need to upgrade in a set of aftermarket LT1 heads. As of today I will be using the Dart 180's. I will be running a D1SC intercooled with 14-16lbs on a 383. I want to make sure that I have no issues, but do not want several hundred $ of overkill. Thanks
Old Jan 24, 2008 | 09:27 AM
reamo04's Avatar
well, are you getting them off the shelf, or ported by somebody? To maximize power, you will want them ported.
Also, make sure to have low enough compression
Old Jan 24, 2008 | 12:08 PM
RUNMYTA's Avatar
Reamo04, thanks for the reply.
I guess I should be more clearer. Should items such as springs, locks, stem guides, rockers, or the moving parts be upgraded for boost?
\Thanks!
Old Jan 24, 2008 | 05:00 PM
reamo04's Avatar
\Thanks!
im not ENTIRELY 100% sure, but, everyone ive seen is just running the same stuff as what people are for N/A cars
hopefully somebody else will chime in
Old Jan 25, 2008 | 08:20 AM
97s10ondubs's Avatar
You just have to overdue the springs a little for the extra boost that's going to be in the manifold pushing against them. My new turbo cam is only .577 lift, but I have springs that are good to .650.
Old Jan 25, 2008 | 03:32 PM
BLWNLT1's Avatar
and what springs are those?
Old Jan 25, 2008 | 03:47 PM
RealQuick's Avatar
You need more seat pressure for the valve (installed height will affect how much seat pressure there is).
Old Jan 25, 2008 | 04:54 PM
pac 1518
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Jazsun
Dec 29, 2014 12:14 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
