what can happen from reusing a converter?
Old Jan 22, 2008 | 06:15 PM
Critter's Avatar
rebuiling the trans, but reusing my converter. The 2-4 clutches were near gone from low line pressure and you can tell it was getting hot. I was planning on reusing the converter for now (till i get some more $$$) what could happen in the worst case senario?
Old Jan 22, 2008 | 06:33 PM
Performabuilt's Avatar
Supporting Vendor
Converter clutch could be bad from the low line presure also , Contamination could get in the trans from the old converter. I never consider this a good idea
Old Jan 22, 2008 | 06:35 PM
mdacton's Avatar
If you had any previous failure its a bad idea. Will just get that trash in the new trans.
Old Jan 22, 2008 | 07:29 PM
Critter's Avatar
is there any way to flush the one i have? i have no other option but to use this one because money is too tight. Is there anything i can do to make the situation any better?
and by trash do you guys mean old clutch residue. The trans was going out, 2nd was slipping but didn't go all the way i stopped driving it when i noticed it.
Old Jan 22, 2008 | 08:11 PM
Supporting Vendor
Well you can have it flushed better than nothing but not a great idea, But if you check around local you can likley get a reman converter cheap around 100 dollars.
Old Jan 22, 2008 | 08:48 PM
Critter's Avatar
its a stall so reman stock won't work with the cam
Old Jan 22, 2008 | 10:43 PM
Supporting Vendor
Well still its risky but have it flushed at least
Old Jan 23, 2008 | 04:12 AM
rskrause's Avatar
Moderator
If it is a good (expensive) converter it's worth the $100 or so it costs to send it back to the manufacturer to be "freshened up". To do this, the case is cut open, everything made nice, and it is rewelded. Taht way, besides ensuring it is working right, it will be completely cleaned out.
Rich
Old Jan 23, 2008 | 06:27 AM
cause4panic's Avatar
i went to a local tranny shop and asked who did their converters, found someone local that cut, cleaned, welded etc etc for 60$. I tried looking in the yellow pages and internet and had found noone, go to the shops there has to be someone close.
Old Jan 23, 2008 | 08:37 AM
AL SS590 M6's Avatar
Moderator
This is what I was going to suggest.
Old Jan 23, 2008 | 10:07 AM
Z-RATED94's Avatar
Worse case, you'll puke your rebuilt trans. Beg, borrow or steal some money and put a real stall in that thing. Vig. 3400 or a Yank 3600 comes to mind. And don't forget to flush your lines and trans cooler.
jackpawt883
May 21, 2015 12:34 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
