Alternator weirdness
Old Dec 23, 2007 | 07:26 AM
naturally aspirated's Avatar
I got off of work at 7:30 am this morning (est) and while leaving the parking lot I saw that I had a check guages light... I inspected my guages and saw that the voltage guage was in the yellow. . I figured I'd have to limp it home and when I turned out of the parking lot and got on the throttle a little bit and the voltage meter jumped up to about 50% . Driving home it would drop back until just a hair above the yellow but would never throw a check guages alert. Even weirder is every stop light I hit it'd recharge the battery until I shifted into any gear above 4th.
I talked to a friend of mine and he suggested it was a ground wire... does that sound right? Wtf is causing this?
Old Dec 23, 2007 | 09:21 AM
AL SS590 M6's Avatar
Moderator
Not an engine tech question.
Old Dec 23, 2007 | 11:50 AM
qboneus's Avatar
Ground wire is optimistic...
Sounds like you are in the market for a new alternator.
Pull your alt and go get it tested..
Make sure you get a good long warrantied replacement.
Tal
Old Dec 23, 2007 | 12:35 PM
n2ceptor's Avatar
1. Check loose wiring
2. Corrision
3. With a multi-meter at battery terminal, normal idle, voltage should read around 13.8~14.2
4. Have the battery check with a load tester.. Most part stores can do this..
5. As stated above, you could remove alternator and have it checked also..
Nayr
Mar 3, 2023 08:34 PM
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
